10-up wide glide owners don't use a led with separate turn function/color
Thanks, My current set-up is smoked lenses so I'll stick with that. I'm going to purchase the kit and add the tail light also, I have a PIAA bulb for the headlight but yet to install it, going to do them all at once.
Were the fronts a plug & play also? I like the white ring up front with amber turns.
thanks again.
thanks again.
The bulb clusters are just put in as if you are doing a bulb change on the front and back both. The Load equalizer has to be installed under the seat.
I also installed a PIAA extreme white headlight bulb. The LEDs were so bright that my headlight seemed like it was barely there. The PIAA made a lot of difference.
I'll try to remember to get some pics Saturday to post of how they look.
