Need some advice on a sissy bar install
Ok, here it is. 2015 wide glide that has a factory installed short sissy bar. Bought a slims fab farm 24 inch. Slim with infinite wisdom cut a slot for the wires for the turn signal. Should be an easy install. Remove front torx screw, remove rear blinker screws, remove old sissy bar and insert new....no, in Harley's infinite wisdom, the rear turn signal screws are about 3 inches long which means they hit the tire and you can't back it all the way out without removing the rear tire from the bike. Additionally there is no slot for the turn signal wires on the factory bar. They an them straight through the turn signal bolt slots and it would appear they are sealed units with no plugs requiring me to cut the wires and then re spice. Surely I must be missing something. I can't believe I would have to remove the rear tire and cut my turn signal wires just to remove a sissy bar. At least slim thought ahead. If there were no factory bar the slims bar would be a drop in...any advice or am I missing something. If not then the new bar will sit on my shelf until I need a new rear tire. Not looking to disassemble my bike just for a sissy bar removal. Grrrrr!
I got you bro.
Your turn signals/license plate wires run along/under the fender and under your seat where the battery is. There are three plugs there. Unplug them and pull them all the way through the fender. Take a car jack and lift the rear of your bike using the frame. This will raise the fender and should allow the rear bolts to slide out. At least on my street bob it did. I think you may have a wider rear tire so I don't know. Also, those slots on your bar...those were my idea when I ordered it from Slim. Hope this helps.
I recall helping a friend install a sissy bar on his low rider recently and the bolts holding things in were a bear. What I did was as the bolt was coming out, I moved the collar that the bolt goes through which all goes through the fender and it came out no problem. Took a minute to figure out the right combination but it can be done with the tire on. I'm assuming there's some similarity b/w the 2 setups since I haven't worked on a WG.
Thanks
Thanks for the advice, while I was too busy to do the install today I experimented and looked and I have it figured out. By using my motorcycle atv jack I can lift very slightly before the rear swing arm. This dropped the rear tire enough for the bolts to be able to clear. Found the connectors under the seat for the turn signals and that will be no problem on the removal. A bit tight working quarters working under the fender around the rear tire but doable as long as I take my time. Another reason I didn't do it today was because I was in rush mode which means " screw something up" pictures upon completion
Put something between the fender and the bar also when you slide it on. I used a paper bag and it was fine until it ripped and I got a small scratch. Touched it up with the paint pen and it's fine but it's just another thing to watch out for. I also did just the front and then just the back on the advice of others and I'm glad I did. Seems like.it would be hard to get it all lined up otherwise
