Control switch relocation
I'm thinking about relocation the switches off my bars to else where, looking for some input/ experience. Theory is to mount a rocker switch for the run/ kill and a momentary for the starter on the bottom side of the ECU cover. Thinking trip/ horn and high/ low on the side of the horn cover. I dont run blinkers, just a solo taillight outback. Thank guys
It's a 2013 Street bob
I'd say what you're thinking about doing is not a good idea. You need to have those buttons within a half a second reach and not somewhere that you'll have to fumble around and search for in case an emergency arises .Just get a new handlebar set-up where the switches are less noticeable, like they use on some of the show bikes.
http://www.posh-factory.com/product.htm
http://www.ebay.com/sch/i.html?_from...tches&_sacat=0
http://therosshallproject.blogspot.c...ls-part-i.html
http://therosshallproject.blogspot.c...l-part-ii.html
http://therosshallproject.blogspot.c...-part-iii.html
I've done it before and had no real issues. Relocated the ignition to a hidden toggle switch and used a solenoid plunger (similar to http://www.ebay.com/itm/252282095495) on the starter. I didn't have a horn, turn indicators or a high/low beam anymore, so I didn't need them. I did leave the kill switch on the bars but could have done without it.
-G
-G
I can't remember what company makes it, but somebody makes a small 4 button switch assembly that's made to recess into a grip or mount on the bars for this type of application. There was a Street Bob on this forum at one point that ran this setup, looked really clean.
edit: I can't remember the bike I saw it on, but its called the GripAce.
I never said it was a good or bad choice, only provided an option to the OP
mtiberio
05-27-2014 08:02 PM
