S&S Stealth K&N Filter Alternative
Old 06-10-2016, 08:35 PM
DeaD SpacE's Avatar
DeaD SpacE
DeaD SpacE is offline
Default S&S Stealth K&N Filter Alternative
UPDATE
Found a replacement and have one on order.
https://www.brocksperformance.com/Sp...f+I405072.aspx
Is there a filter to replace the K&N filter that comes with
the S&S Stealth.I am tired of having to clean and oil the
K&N filter.
Old 06-10-2016, 09:02 PM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,510 Likes on 2,133 Posts
How often are you cleaning? Unless your breathers are puking a lot of oil, you shouldn't need to clean more then every or at worst every other oil change?
Old 06-10-2016, 09:11 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
I don't clean more than once a year myself.
Does the stealth use a conical filter or cylindrical? I would think you could get a paper element that fits if it's cylindrical. Not sure about conical but maybe...
Old 06-10-2016, 09:12 PM
DeaD SpacE's Avatar
DeaD SpacE
Cleaned it a month ago,oiled the crap out of it and today it is already turning
white.Breathers are bypassed to atmosphere.
Old 06-11-2016, 04:51 PM
Mchad's Avatar
Mchad
Mchad is offline
Just curious how you bypassed with the S&S AC.
I'm about to do it myself, but I think I'm going to do what I did with my last LR - get an Arlen Ness and a Zippers Maxflow filter adapted to it. Plug the vent holes with a couple of 6mm set screws, fill the holes at the top with JB weld (so oil isn't sitting at the top of the screws eating at the red loctite) and drill and tap for hose barbs under the breather bolts.
I prefer to have a cover over the element. Keeps rain off and the red oil seems to fade in the sun. K&n says it's ok, but I don't like it. Can't tell when it's time to clean/oil it.
Old 06-11-2016, 05:45 PM
DeaD SpacE's Avatar
DeaD SpacE
I plugged the drain holes with RTV and used the OEM mounting bolts
and used 90 degree 3/16'' vacuum line over the nipples on the oem
bolts with a tee behind the backing plate.Not real pretty but works.
Old 06-11-2016, 07:27 PM
HHFLHR's Avatar
HHFLHR
HHFLHR is offline
Just use the stock bolts (no need to plug the vent holes as the stock bolts are not banjo style), run hoses from the stock bolts to a Y junction behind the A/C cover and vent to atmosphere or catch can.
Old 06-12-2016, 01:24 PM
nevil's Avatar
nevil
nevil is offline
"Oiling the crap out of it." Leads me to think you use too much oil. In this case, less is better than too much.
Old 06-12-2016, 02:37 PM
Mchad's Avatar
Mchad
Mchad is offline
Yeah, I'm one of those crazy dudes that would still plug them. Otherwise I may be the 1:1000000 lucky guy to have a speck of sand getting sucked in. Naturally that would never happen, but I'd plug them nevertheless.
Thanks
Old 07-15-2016, 07:36 PM
DeaD SpacE's Avatar
DeaD SpacE
to the top
TriGeezer
03-07-2015 03:43 PM
P51Driver
11-22-2012 10:43 PM
studiopeg
01-18-2012 12:38 PM
ezryder1962
Oil Archive (no new posts)
04-27-2009 11:53 AM
1sportytrike
10-10-2007 09:34 AM
Quick Reply: S&S Stealth K&N Filter Alternative
