No light with fuel pump prime?
Old 06-23-2016, 07:33 PM
djKail's Avatar
djKail
djKail is offline
Default No light with fuel pump prime?
Hey everyone, just joined the Dyna family! Picked up a 2014 low rider with ABS and Security and am noticing the the Check Engine Light is not illuminated when the pump is priming.
Light is good because it does light up when I turn the ignition on. However, after it goes out, I flip the Handlebar switch to the "run" position, hear the pump prime, but no light.
Manual states the light should be on for about 4 seconds while it primes, which is how it was on my sporty.
Anyone else encounter this? Seems to turn over OK everytime and runs alright.
Old 06-23-2016, 09:54 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
Why are you using the "handle bar switch"?
Does the ignition not work?
Your throwing the ecm into run or not run with that switch and expect it to act the same?
Old 06-23-2016, 10:14 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
not your sporty. you are fine... read your owners manual.....
https://www.harley-davidson.com/cont...rs-manual.html
sporty87
12-22-2015 12:33 PM
alzylstra3
11
06-30-2015 10:57 PM
cananderson33
06-09-2011 06:16 AM
04rdkng
06-28-2009 04:49 PM
DLX
01-04-2007 01:11 PM
Quick Reply: No light with fuel pump prime?
