Fuel pressure light problem..
Old Jun 27, 2009 | 09:57 PM
04rdkng's Avatar
04rdkng
Stage II
Default Fuel pressure light problem..
Hey guys I have a 2004 Road King with fuel injection, when i go to start it i turn on the main switch and then the on/off switch and wait for the amber light on the speedo to go out. After it goes out i go to start it and then the amber light comes back on.. most times it will start and eventually the light goes out after a while takes usually 5 to 10 seconds. Does anyone know what is causing this i appreciate it.
Old Jun 28, 2009 | 02:11 PM
robzuc97's Avatar
robzuc97
Check to see if you have any historic codes in the self-diagnostics. Sounds vaguely like you do.
Old Jun 28, 2009 | 04:49 PM
lacefieldusaf's Avatar
lacefieldusaf
6th Gear
You have a code stored in the ECM. Sometimes the ECM will store a code if the bike has a misfire or something small that isnt really a problem and only happens once. The ECM will remove this code after 50 revolutions of the ignition switch or you can remove it yourself. Use the self diagnostics to read the code or go to a dealer and have them plug the bike in.
sporty87
Dec 22, 2015 01:04 PM
sporty87
Dec 22, 2015 12:33 PM
roadkingbigjoe
Jul 23, 2008 07:13 PM
eg1997
Aug 26, 2007 05:45 PM
EVOrider
11
May 25, 2007 10:00 AM
