cold start
Old 11-07-2016, 09:52 AM
GLS45's Avatar
GLS45
GLS45 is offline
Stage II
Default cold start
10 super glide, on cold mornings slow crank,won't start, 10 min. later will crank an start, battery up an good. anyone got any ideas to problem?
Old 11-07-2016, 10:33 AM
danhahn's Avatar
danhahn
danhahn is offline
I think it's your battery showing first signs of aging.
I'm assuming you looked at battery connections already.
Old 11-07-2016, 11:43 AM
danhahn's Avatar
danhahn
danhahn is offline
Does a V INERR code come up on your odometer when it's doing it's slow crank?
Old 11-07-2016, 11:51 AM
nevil's Avatar
nevil
nevil is offline
Unless you get your battery load tested don't say it's good, especially if it's the original with the bike.
Good advice about checking battery and ground cable connections.
Old 11-07-2016, 11:58 AM
natedog_37's Avatar
natedog_37
natedog_37 is offline
Had issues kind of like that. Was the Battery.
Old 11-07-2016, 01:22 PM
GLS45's Avatar
GLS45
GLS45 is offline
Stage II
Default cold start
New Battery in Feb.
Does a V INERR code come up on your odometer when it's doing it's slow crank? How do I get this code?
Old 11-07-2016, 03:10 PM
danhahn's Avatar
danhahn
danhahn is offline
It will come up automatically while the starter is attempting to crank the engine. Then it disappears as soon as you release the start button. At least that's what my street bob did a couple of times when it cranked real slow. I think the starter would even stall if I remember right.
Somehow it cured itself. I rode it 2 or 3 more years without the code reappearing, unless I just didn't notice.
Old 11-07-2016, 03:17 PM
danhahn's Avatar
danhahn
danhahn is offline
Welcome to the forum, by the way.
Old 11-08-2016, 01:24 AM
JustOneDean's Avatar
JustOneDean
JustOneDean is offline
Sounds like an aging battery. If you're getting a V INERR, that's "voltage insufficient."
Old 11-08-2016, 06:45 AM
skinman13's Avatar
skinman13
skinman13 is offline
Originally Posted by GLS45
New Battery in Feb.
I don't know about codes, but I do know about battery systems and you are describing a classic weak battery problem.
You have looked at the obvious so now you really need to load check your battery even if it is only 8 months old. Know for sure it is not the battery before tearing into your system. You can do a quick check by putting a volt meter directly across the battery terminals and cranking...if your voltage is dropping to say around 9.25 volts or lower, that will indicate that you have a battery/charging system problem.
I had one go ATU that was less than 6 months old...only there was no slow-starts, it just would intermittently not work. I am convinced it was because I kept it on a tender...I never used tenders routinely before and I do not anymore.
Quick Reply: cold start
