O2 sensor, V&H and PCIII????
Old 04-30-2008, 11:47 PM
70mach1's Avatar
70mach1
70mach1 is offline
Default RE: O2 sensor, V&H and PCIII????
Not trying to highjack thread but was wondering ?
IfusingPower Commander with BSS and Stage #1 ,I can use plugs in pipes instead of 02 sensors ?
What abought the Vance and Hines Fuel pack ?? Is it the same deal ??
Just wondering if anyone knows for sure ....
Old 05-01-2008, 06:33 AM
shimmon's Avatar
shimmon
shimmon is offline
if you go with the PCIII then you can plug your o2 sensors since they are not used. the fuel pac uses the sensors, i have been wrong before though! i did find a couple of drain plugs and they fit great. i am installing the pipes tonight... hope to get a pic up when i am done.
and as for the stupid looks... yeah i called the local dynojet dyno tuner in my area... spoke to a chick in parts and i told here i was looking for an "O2 sensor plug". she said she didnt really know what i was talking about, then ask what bike i had "an 02(read zero, two) what?" and i said never mind! give me to someone in service!
Old 05-01-2008, 06:35 AM
shimmon's Avatar
shimmon
shimmon is offline
i should mention that the local tuner is a suzuki dealer......
also you guys that used plugs... did you use any type of washer... the guys at carquest (whom i know pretty well) told me they would put a copper washer there instead of the supplied plastic one. i was either going with a copper, steel, or no washer at all. thoughts?
Old 05-01-2008, 06:48 AM
ehretja's Avatar
ehretja
ehretja is offline
I went with no washer at all. It came with a plastic one but i yanked that off. I was wondering the same thing before i did mine. I thought the O2 sensors had a copper crush gasket. I was at a dealer and asked them the same question. I was told that i didnt need one for the plugs. The guy at the dealer pulled out some plugs from drag specialties and they didnt have any washers. I would think that as long as you've got that plug well seated and you've got a metal to metal face seal on the the bung you'd be good to go. I've got a couple hundred miles on my bike since my install 2 wks ago and have had no problem yet.
Old 05-01-2008, 02:44 PM
Graduate's Avatar
Graduate
Graduate is offline
I didn't use any washers just never seize
Old 05-02-2008, 07:24 AM
shimmon's Avatar
shimmon
shimmon is offline
ok guys i got her done last night... took her for a quick spin and she is only has some minor popping on decelration... i know there is posts somewhere in here on how to adjust the curve to fix the problem. so i will be adjusting my map a little tonight or this weekend to try to fix this and set my zero throttle and WOT. thanks for all the help guys. i ended up using the copper washers.
total install time for A/C, Pipes, and PCIII was about 2-2.5 hours. if you have a few tools and a little know how you can do all this yourself in no time at all!
http://i284.photobucket.com/albums/l..._2008/BIKE.jpg
http://i284.photobucket.com/albums/l...8/DVC00064.jpg
Kockdiesel
08-12-2008 06:34 PM
Motosportman
06-27-2008 02:00 PM
blacked out
05-28-2008 03:21 PM
JFjeld
09-12-2007 10:16 AM
waterman7474
09-21-2006 11:37 AM
Quick Reply: O2 sensor, V&H and PCIII????
