06 FXDB forward controls
Old 12-01-2008, 07:50 PM
o~~'s Avatar
o~~
o~~ is offline
Default 06 FXDB forward controls
Hello all! I'm reading the instructions for the HD Dyna forward control kit for my 06 FXDB. It looks like you have to remove the entire primary case and clutch just to get the mid shifter lever out. My question is for anyone who's done this before:
* Is there a way to do this without removing the primary case and clutch?
Thanks!
o~~
Old 12-01-2008, 08:21 PM
Grind's Avatar
Grind
Grind is offline
If you search "forward" you'd find this, eventually.
Originally Posted by WS6 formula
You don't have to remove the primary on the 2006 and up Dyna's
The 2006 and up kit requires you to remove the primary to install a longer rear transmission shift lever and to remove the original shifter shaft that goes through the primary cover. Both can be done without removing the primary.
I installed the cheaper 2005 kit with a longer 2006 custom polished stainless steel shift rod that comes with the stronger heim joints (they won't break like the original joints). You have to use a longer shift rod with the 2005 kit other wise the front shift lever will hit the primary when you up shift. The custom shift rods are a lot nicer then the original, and the kit included cadmium plated shift rod.
Removing the original shift shaft lever
Get a hacksaw blade and tape each end with duct tape, leaving about two inches exposed in the middle. Also put some duct tape on the primary and cylinder cooling fins. Tape a wrench on one end to get a better grip (on the end of the blade so as you pull on the wrench you will be on the cutting stroke of the blade). Slip the blade between the primary and engine from the bottom of the bike with the wrench end on the bottom. Position the shaft so you can cut about a quarter inch from the lever (not in the welded area). Use your other hand to guide the top of the blade as you cut. After cutting through, the shaft will slide right out, and the lever will just fall to the floor.
Cover for the original shift shaft lever hole
I used a chrome carriage bolt http://www.chromebolt.com/51618-x-13...olt-p-845.html, and put a two inch piece of rubber hose on the threads then added some shrink sleeving on the hose to get a nice snug press fit into the empty shaft hole. If you have a black primary: Paint a unplated carriage bolt. Aluminum cover: Scotch brite a chrome carriage bolt.
Installing the new rear trans shift lever
https://www.hdforums.com/m_3212510/tm.htm
(Don't do it, leave in the original) Using the original rear transmission shift arm has two benefits, appearance and performance. The shift rod will sit at a more level position, and you will also have a shorter shift throw.
Forward control part numbers here:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Shift linkage part numbers here:
http://www.harley-davidson.com/brows...bmLocale=en_US
Check prices here:
https://www.zanottimotor.com/shopping/partLookUp.html
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
Many of us have installed forwards without pulling the primaries. You can simply cut the shufter shaft at the arm between the inner primary and the engine/tranny case.
Here are a couple related links:
https://www.hdforums.com/m_576946/tm.htm
https://www.hdforums.com/m_613252/tm.htm
Old 12-01-2008, 08:22 PM
jmpancoast's Avatar
jmpancoast
I type too slow. Sorry for the duplicate info.
Old 12-01-2008, 08:25 PM
Grind's Avatar
Grind
Grind is offline
Ah, but my cut&paste doesn't have the nice picture yours does, jmpcoast.
Old 12-01-2008, 08:27 PM
JayFromPa's Avatar
JayFromPa
JayFromPa is offline
The WS6 method described above is the simplest way to completely do away with the shaft.
Old 12-01-2008, 08:31 PM
cbass68's Avatar
cbass68
cbass68 is offline
I followed these instructions to the "t" when I changed to forwards recently. Did a great job! Question though, ever since, I have a hell of a time finding neutral. Any suggestions?
Thanks!
Old 12-01-2008, 08:35 PM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
If you don't want to cut and remove the shifter shaft you can slide it in toward the center of the bike and push it forward wedging it behind the bolt head coming out of the crank case. I rode for two years with this set up before finally taking the inner primary off and removing the shaft.
Old 12-01-2008, 08:36 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Thanks!
Try re-adjusting your clutch.
Old 12-01-2008, 09:39 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Thanks!
With this set up you have a shorter throw, so you just have to adapt to not moving your foot that much, try just tapping the shift lever with your foot.
Quick Reply: 06 FXDB forward controls
