New 2" Tank Lift On My FXDC
Old 12-06-2009, 02:55 PM
Wonkaboy's Avatar
Wonkaboy
Wonkaboy is offline
Lightbulb 2" vs 3"
Any comparison photo's of bikes with 2" and 3" design ?
Old 12-06-2009, 03:05 PM
Unkwaldo's Avatar
Unkwaldo
Unkwaldo is offline
Default Tank Lift
Who makes a good tank lift kit?
How much do they cost?
Do you have to modify anything else on a 06 Street Bob to do a tank lift?
Thanks in advance.
Unk
Old 12-06-2009, 03:38 PM
2007fxdc's Avatar
2007fxdc
2007fxdc is offline
Thanks in advance.
Unk
Forum member Jackyl makes and sells them. Well under 50 bucks shipped. Good quality stuff. No mods necessary for the 2" lift. For the 3", probably have to replace the crossover hose with a longer one.
Old 12-06-2009, 05:01 PM
Andjh123's Avatar
Andjh123
Andjh123 is offline
A few functional purposes (arguably) of the tank lift:
1. Easier to clean heads
2. Better airflow/cooling
3. Can run a hair closer to a completely empty fuel tank (anyone see that Seinfeld episode?)
4. Moves the blast of air a little higher on the body when cruising
5. Makes you feel like you're sitting more "in" the bike rather than "on" it
Old 12-06-2009, 05:29 PM
ezy_rider's Avatar
ezy_rider
ezy_rider is offline
IMO - tank lifter look better when tank is whitout console...
Old 12-06-2009, 05:59 PM
Steve Zodiac's Avatar
Steve Zodiac
Steve Zodiac is offline
I fitted a 2 inch tank lift and didn't like the look of it so I took it off after a few weeks. I guess it looks better on some bikes than others.
I don't know if it made the engine any cooler but it definitely made it easier to clean.
Before I fitted it the gauge was showing slightly less than half full. After lifting the tank it showed quarter full. I reckon that it alters it by about a gallon.
Old 12-07-2009, 03:19 PM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I think a 2" lift looks great on a Dyna...really stretches out the look of the forks, especially a Wide Glide. I had to replace the short vent tube (just exiting the tank) with a little longer piece. You can mitigate the fuel gauge issue by raising the rear a little, like I did. Here's a couple of pix. Search my "Tank Lift..." thread from this last summer for more pix and explanations...
PM requested a full-on side view, after the tank lift & rearward shift. The rearward shift was so the upper tree pinch bolts wouldn't hit the tank at full R/L stops (no seat interference). I also have 11" Progressives that lowered the rear. The lift makes my stock mini-apes look too low, so I think my next mod will be 4"-6" risers.
Old 12-07-2009, 03:51 PM
jackyl's Avatar
jackyl
jackyl is offline
dam that looks good lifting the rear also,thought of it but never did it or seen it, great job. i think i might have to do that now. jackyl
Old 12-07-2009, 08:21 PM
dpriest's Avatar
dpriest
dpriest is offline
gotta disagree on #3. the fuel pickup on an injected dyna is closer to the center of the tank. lifting the front of the tank pushes the available gas towards the rear giving you more of an unusable reserve. Not that it make a big difference, just saying.
one more thought. it also makes the guages easier to read. on the lowrider anyway.
Old 03-25-2014, 12:28 PM
suazosuperglide's Avatar
suazosuperglide
suazosuperglide is offline
Stage I
Default springer seat
Originally Posted by Bobber S
Fuel guage is definately effected by the 2" tank lift. My low fuel light goes on when tank is a little less than half full ! Other than that it is a good value DYI mod.
sir, where did you get that seat?
animalnoll
01-08-2011 09:59 PM
toastman
03-19-2010 06:16 PM
VA Biker
07-22-2009 06:40 PM
rounder
11-20-2008 09:33 AM
TEK 679
02-21-2008 09:46 PM
Quick Reply: New 2" Tank Lift On My FXDC
