Fuel inductor light on w/plenty of fuel?
Old 08-15-2010, 01:44 AM
mvinc01's Avatar
mvinc01
mvinc01 is offline
Default Fuel inductor light on w/plenty of fuel?
Last Sun, at the end of a 280 mile ride, the low fuel indicator light came on and the fuel gauge skipped down to low fuel flashing light. I had plenty if fuel in the tank. I pulled over and topped off at the next station, but the indicators stayed on even after filling up. I've double checked the electronic connections on the fuel gauge cap as well as the fuel filler cap. Both are installed correctly. I've ridden since then and there seems to be no effect of the ride quality or engine effects. The lights are still on.
Could this be a bad fuel gauge, or possibly a bad fuel sensor sending unit? Is there a way to reset this?
Any ideas or suggestions are appreciated.
Thanks!
Old 08-15-2010, 01:57 AM
ratt196635's Avatar
ratt196635
ratt196635 is offline
if you have the old gauge put it back on and see if the problem goes away More than likely that led guage has a problem or you might try unpluging it and see what happens
Old 08-15-2010, 09:18 AM
mvinc01's Avatar
mvinc01
mvinc01 is offline
Thanks Ratt. I've already disconnected-reconnected the gauge and checked it. I don't have the original because these came w/the bike. I'm hoping its just a faulty gauge and I'll just go he the skull gague/cap. Hope its not internal in the tank.
Old 08-15-2010, 09:23 AM
mvinc01's Avatar
mvinc01
mvinc01 is offline
BTW...The title should be "Fuel indicator light on w/plenty of fuel?"
Darn spellcheck...Grrr...
Old 08-15-2010, 09:33 AM
HBomb74's Avatar
HBomb74
HBomb74 is offline
That's a great avatar pic by the way...
Old 08-15-2010, 09:36 AM
Grendel4's Avatar
Grendel4
Grendel4 is offline
It makes me dizzy.
Old 08-15-2010, 09:41 AM
ORIGSQUIG's Avatar
ORIGSQUIG
ORIGSQUIG is offline
Thanks!
Sending unit went bad or open circuit in wiring, check with ohm meter, you may need to buy service manual for chek out procedure
Old 08-15-2010, 10:08 AM
jrobinson424's Avatar
jrobinson424
jrobinson424 is offline
I had the same problem with my 2010 FXDC. I'd fill up, go 50 miles, and the gauge would say empty. However, the computer was right saying I had 160 miles to empty. Took it to the dealer and they said the Fuel Level Sending Unit had gone bad. They said this is a pretty common problem. They replaced it for me. Just really weird that a brand new bike is already having stuff go bad.
Old 08-15-2010, 01:24 PM
HDTech74's Avatar
HDTech74
HDTech74 is offline
2 things it could be
alot of times the float level arm gets caught up on the tank and doesn't let it rise or return.
secondly it could be the sending unit itself, which is common. you can check the resistance on the sending unit, it's just a reo-stat/potentiometer. there is no set resistance according to the harley electrical manuals. it will have resistance but no the right amount.
if you know how to get it out, take it out and lay it on the top of the tank, turn the bike on and move the float, if you move the float up and the gage doesn't move you know it's the sending unit.
If youve never taken the fuel pump assembly out of a tank before
because if you've never done it you'll break it, leave it to the dealer.
Old 08-15-2010, 10:03 PM
mvinc01's Avatar
mvinc01
mvinc01 is offline
Thanks. Funny, that's what my wife said too. I stole it. It's pretty common.
Originally Posted by Grendel4
It makes me dizzy.
OK. Thanks guys for the input and advise. I was hoping not the sending unit, but you're probably right that it likely is. I'll probably check with the dealership on price. Probably be a grip for a faulty part. Sux. Thanks again.
Quick Reply: Fuel inductor light on w/plenty of fuel?
