Thinking of Handy SAM 1000 Lift for My Dyna
Howdy All,
Thinking of pulling a trigger on a Handy SAM 1000 Lift to help me work on my 08 Street Bob.
However, I am not sure whether the optional scissor jack will work with my Dyna?
With a standard floor jack, we use lift adapters. However the scissor jack supplied by Handy is lot narrower. Would I still need to use a lift adapter with a Handy scissor Jack? If not, how do you position the scissor jack to ensure that bike is stable when jacked up?
Can anyone please comment?
Thanks
Thanks
Manufacturer's Site:
http://www.handyindustries.com/shop/...t=936&D=1&S=21
Review:
http://www.handyindustries.com/shop/...&idProduct=936
Review:
Scissors Jacks
If it is the same one as in the pictures, you shouldn't have any problems. I have a Blackjack that I use often and the one in the pics looks almost as wide as mine.
I place it just forward of the rear wheel to lift the tire off the ground (where the swing arm mounts). To raise the front, I put it just under the forward motor mount.
I don't have a table lift but it works well on the garage floor without any lift adapters.
My dad has a Handy lift. He bought it back in 2000. I will say this, It is a great lift. The only problem he has had with it was the seal on the ram. It was an easy and cheap fix.
After using his lift for a couple years on my bike. I decided I needed a lift. I started shopping around and found mine.
http://www.gregsmithequipment.com/Di...rocycle-dt.htm
Fit and finsish is not quite as nice as the Handy, but the difference is marginal. If you never saw a Handy, you would think this lift is the best one around. The foot pedal on mine is slightly nicer than my dads Handy, but they might have started using a new pedal since then.
I'm not trying to tell you your business, but I would pass on the Handy and buy a direct lift. It is about half the price, does the same job and I like the diamond plate better than the smooth finish of the table, it helps keep sockets from rolling off the table when you drop them.
I use their Black Jack scissor jack on the lift. It came with adapters, and a large plate that slides on it for larger jobs. I had a Road King on my lift on the black jack, both wheels off and strapped down. It was very stable and I had no worries.
Kendon............. http://www.kendonusa.com/lifts.html
