Drain Gas From Fuel Tank
While those are good explanations of draining the tank, you do not need to remove the tank to get to the wiring. Just remove the bolts, get a couple towels and slide the tank back and up as much as the crossover will allow. Use the towels to protect the paint. Push the wiring slack up from under the seat as you gently pull it out of the neck. The wiring is all in one bundle coming up the spine. It splits out just before it emerges from the neck.
So if I am relocating turn signals (which I am), all I really need to do is pull the wiring harness up toward the bars and find the connectors there?
I know it may seem like a dumb question, but I am trying to learn - and my manual does not make this clear.
USMAMule
Doug,
USMAMule
USMAMule
