Blinkers stuck on now not working at all.
I rode my bike to work today and the blinkers and horn worked fine the whole way in, went do a vehicle inspection on it about an hour ago and hit left blinker (worked) right blinker (worked) 4 ways (worked) when i went to shut the 4 ways off they wouldnt turn off i had to pull the fuse and now the blinkers, 4 ways, and horn do not work. I checked all of the fuses and they are good. any ideas on what else it could be? maybe a relay? short? or the switches?
appreciate anyhelp
appreciate anyhelp
somebody correct me if i'm wrong, but these bikes don't really have conventional turn signal relays do they? Isn't it all handled be the circuitry of the TSSM?
I would start by disconnecting the battery for a bit and re-seating the TSSM.
Just a simple suggestion before you go digging into harnesses and opening switch housings.
You said you checked the fuses. Did you just eyeball them or did you use a meter or continuity tester? I've seen fuses that looked intact but were blown.
If you have a load equalizer for led sigs it could have a glitch and need to be reset.
You have a TSSM for your sigs and security. Is the red key light on? You might have to reset the TSSM:
step # 1. move handle bar kill switch to off position
step # 2. turn your ignition key: on-off, on-off then on
step # 3. hit the left turn signal twice.
your turn signals and indicator light will flash 1 - 3 flashes
step # 4. hit the right turn signal once.
turn signals and indicator light will flash once.
step # 5. hit the right turn signal once.
turn and indicator signals will flash twice.
step # 6. hit right turn signal once.
turn and indicator signals will flash three times.
step # 7. hit left turn signal once.
turn and indicator signals flash to indicate error code
(see error code thread)
step # 8. to now clear codes, hit left turn signal and hold down for 6 seconds until confirmation.
turn and indicator signals flash twice.
step # 9. turn the ign switch to off
Thats it, TSSM is now reset and ready to roll
I did recently have a tire put on Yesterday was the first day i rode it since. I Got an error code but nothing for the turn signals. it was no combustion rear cylinder but was a historical code. I pulled the fuses and tested them tried replacing the relays. everything I Have read so far leads to a short. im guessing that my wiring harness got knocked loose during the tire swap. I am going to tear the rear apart tonight and I will let you all know what the verdict is.
Thanks For the help
Thanks For the help
cgrafton
06-03-2018 08:46 PM
