no turn signals or horn?
Old Jan 25, 2010 | 09:13 AM
robertj74's Avatar
robertj74
Default no turn signals or horn?
hello,all-got a short ride in Sat.,noticed when I went to mahe a turn i had no signal,no arrow on the dash,right or left,also the horn did'nt work,i did'nt think to try the high beam so I'm not sure about that,my front marker lights worked,just no signals,rode a few moe miles,then thet started working.
must have had a poor conection in the handlebar wiring somewhere.
any thoughts?
Thanks!
Old Jan 25, 2010 | 09:31 AM
ImNoPrince's Avatar
ImNoPrince
Check your Fuses for corrosion as well. Most Bikes that fuse run the Turns and Horn so might be something there as well.
Old Jan 25, 2010 | 09:46 AM
jmpancoast's Avatar
jmpancoast
+1 on the fuse. The accesories fuse work the signals, horn and brake light.
I would bet, if the fuse is blown, something else is contributing to the issue. If so, I would start with wiring for the rear signals where they travel from the rear signal head, through the stalk, then the fender strut, then under the fender.
Old Jan 25, 2010 | 10:20 AM
robertj74's Avatar
robertj74
Thanks guys,fuse is'nt blown,they started working again,I'll check around the fuse box for corrosion,i removed all the fuses and dielectric greased them when I first got the bike.
mpsmith
Jul 9, 2022 02:15 PM
vindyl
Mar 29, 2014 11:22 PM
Cup
Mar 25, 2012 07:59 PM
Hollywood Ball
Jun 6, 2009 08:02 PM
juaniosa
Feb 6, 2008 11:16 AM
