39mm to 49mm front end swap?
Old 05-12-2012, 04:13 PM
ok_jcv's Avatar
ok_jcv
ok_jcv is offline
Default 39mm to 49mm front end swap?
I know it's been talked about, but does anyone have a complete parts list for a 39mm narrow glide ('03 FXDL) to 49mm mid glide (possibly '06 FXDBI style) front end swap?
Old 05-12-2012, 09:25 PM
ok_jcv's Avatar
ok_jcv
ok_jcv is offline
Just posted these in another thread, but here's the bike I'm thinking about doing the swap on. Any thoughts?
Originally Posted by ok_jcv
This bike was past down to me when my dad past away. I just started to do some stuff to it, but not a bad start.
Old 05-12-2012, 10:50 PM
Dirknar's Avatar
Dirknar
Dirknar is offline
I just did this swap last winter. I scored a really nice 06' sb forks and trees off Ebay for 450$, then I took them apart and got them powdered black. I got the mid glide wheel and fender from members on here and the wide glide headlight of of Ebay as well. You have to make a notch in the stem with a Dremmel so you can still use the lock in the neck of the frame. I had to move my gas tank back about 1/4"because the trees were hitting the tank. Then you have to lose our relocate the indicator/idiot lights. I put mine in the dash panel. Be sure and replace the bearings and races too.
Old 05-12-2012, 11:04 PM
Dirknar's Avatar
Dirknar
Dirknar is offline
Old 05-13-2012, 01:24 AM
ok_jcv's Avatar
ok_jcv
ok_jcv is offline
Thanks for the link, that helps a lot.
Looks like your bike turned out awesome! It's nice to see before and after pics.
What did it take to move the tank back that 1/4"? Also, any idea of how or if it's possible to use the original fender? Some spacers maybe? It would probably be a pain to have a fender repainted to match the 100th anniversary paint with the stripes on it.
Old 05-13-2012, 02:04 AM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
On the '06-later 49mm lower sliders, the bolt pattern for the fenders is vertical vice the horizontal pattern for the '05-earlier fenders ... you would need to get or make a kind of 'L' or '7' shaped adapter in addition to spacers in order to be able to reuse the fender ...
R/
'Chop
Old 05-13-2012, 02:13 AM
ok_jcv's Avatar
ok_jcv
ok_jcv is offline
Thanks, I wasn't sure of the difference. That probably wouldn't be that difficult. I should have looked at this stuff while I still had my Street Bob.
Old 05-13-2012, 11:16 AM
Dirknar's Avatar
Dirknar
Dirknar is offline
Thanks, I like the look of the mid glide forks a hell of alot more. I just bored out the holes in the tank mounts to get it to move back. Not sure about the fender.
geter712
10-10-2017 03:43 PM
71Onealfan
2014-2023 Touring Models
13
04-28-2016 07:27 PM
xjayx
07-03-2013 01:12 PM
ripper43
04-03-2010 06:54 AM
doulos
02-06-2008 08:42 PM
Quick Reply: 39mm to 49mm front end swap?
