rear blinker/running/brake light help
Ok, just put on my sissy bar. had to feed the rear blinker wire through the slot to put on the sissy bar.
Now my left rear light only works as running light, no blinker, no brake
right works fine
switched bulbs.....
now left works as running and brake...but no blinker
any ideas?
would a pinched wire cause this?
right works fine
switched bulbs.....
any ideas?
Hey there. When I moved my rear lights, the contact seat for the lightbulb (white thing with 2 metal points) had rotated in the housing, which resulted in a similar effect you are describing. I fiddled with it a bit and got it seated correctly and that sorted out the problem. Hope you get it fixed...I was frustrated for sure!
Chaseg08
11-22-2009 04:02 PM
