ticking sound
ticking sound
I recently started to have a ticking/tapping sound after starting the bike. In about 4/5 seconds the noise goes away. It happens no matter if the bike is cold or warm.
The bike is a 2009 FXD, with 8k. V&H short shots, SE Airfilter, SE comp and power vision. No issues during riding or idle.
The shop tells me it might be an issue with the cam chain tensioner shoes (worn or weak spring), but if that is the case why would it only occur after starting and then go away? I know it is hard to pinpoint without hearing it, but any suggestions are welcome.
Kind of unlikely to be the cam chain tensioners (also, they have no springs like the earlier pre-'06 models had, since your cam chain tensioners are hydraulic) ... not saying it is impossible ... just unlikely, given the relatively low miles (8,000) ...
Be sure to post up the solution to the issue for others who may be trying to diagnose a similar problem ...
R/
'Chop
R/
'Chop
FXD_noob
01-24-2013 09:17 PM
