Tyre Wobble????
Tire wear or....
....the dreaded low speed wobble.
While this shaking in the front end could be caused by uneven tire wear or cupping, more often than not the wobble in the front end is caused by an improperly adjusted steering neck bearing.
You should be able to search through previous posts and find more info on the cure.
Unless you ride a RoadGlide, it should be a relatively simple fix.
Good luck!
GSF
Good luck!
GSF
irtmks
01-11-2019 04:19 AM
