2012 fxdb suspension help
i have a 2012 dyna street bob and i would like to upgrade the suspension (front and rear) so the bike can get even better. i wanted to lift the bike so i can turn lower. so my questions are what shocks do u recommend for the rear (and i need them tall)? what springs do you recommend for the front? can you lift the front end of the bike? what fork braces or steering stabilizers would you recommend? and where would you get the above listed parts ?
thanks for ur time everyone
adam hffh
adam hffh
Lots of info in this thread on the forks:
https://www.hdforums.com/forum/dyna-glide-models/764904-front-suspension-upgrade.html
For the rear, works performance makes an economical shock that performs well. Ricor does as well. From there the price increases significantly to Ohlins and JRI.
You can expect to easily spend $450 on shocks. The front end setup in running, as described in the thread, can run as cheap as $300 for springs and valves, up to around $750 to add a fork brace and preload adjusters. The options to increase performance from there are, once again, substantially more expensive. Howard at motorcycle metal builds an Ohlins 30mm drop in cartidge, but I beleive it's upwards of $1500.
Only been able to take a short ride so far, tried to do as much cornering as I could - no more wobbles. The only way I can describe the handling now is the bike just seems to be more solid and working together better. You just lean and the bike seems to stay on track and not stray at all. Good luck on your decisions!
The most important mod you can do to your front forks is ricor intimidators. I don't think it would be a good idea to lift your front...your not going to turn any sharper.
You can adjust how stiff or soft you want it when you adjust your front end sag.
When you do your rear shocks you can go 13 or 13 1/2" and that will give you a great ride and give you added travel.
awoitte
08-08-2018 05:24 AM
