Stage 1 Hp & Tq
Old 04-14-2013, 10:22 AM
peter deering's Avatar
peter deering
peter deering is offline
Default Stage 1 Hp & Tq
I have a 07 sg screamin eagle slipons w/cycle shack baffles, V & H Vo2, and Xieds. There is no where on the rock to get a dyno, therefore I would like to know what anybody else running a similiar set up is getting.
Old 04-14-2013, 02:42 PM
rooti's Avatar
rooti
rooti is offline
who cares? why would you even put it on the dyno just to find out...don't quite understand your logic
Old 04-14-2013, 02:57 PM
outback2970's Avatar
outback2970
outback2970 is offline
I think that means you wouldn't be far off from a stock baseline run with those mods. Really not worth the dyno time/money unless you were having issues and needed a good tune. Sorry I can't help with numbers, rock on.
Old 04-14-2013, 03:54 PM
WG2011's Avatar
WG2011
WG2011 is offline
Very tough to tell you numbers, as they very. As long as she runs good that's all that matters at this point.
Old 04-14-2013, 04:18 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
You might get 3-5HP extra.
Old 04-14-2013, 05:03 PM
Gommee's Avatar
Gommee
Gommee is offline
Devil's Advocate
If it is running good for you, no need to run a dyno and waste money unless you want to see what you are getting out of it. If you install a tuner and do any motor upgrades like cams, you would want to get it tuned properly. Even then, it depends on the tuner you install and the need to get it dialed in.
Only you can decide what you want to get out of your bike. Some will say you need to get every ounce of power out of it, you may be happy with the way it runs and ride it the way it is.
Save your money for future mods!
Old 04-14-2013, 06:04 PM
Qdog002's Avatar
Qdog002
Qdog002 is offline
I`d like to know also
Old 04-14-2013, 06:52 PM
NSCoyote's Avatar
NSCoyote
NSCoyote is offline
if you got a good balance of MPG and performance going on without any "issues" or gremlins then dont worry to much about numbers. but you should see a 3-5hp gain with a stage 1
Old 04-15-2013, 01:29 AM
Foxster's Avatar
Foxster
Foxster is offline
Does it have O2 sensors or was that only on models from the next year?
Old 04-15-2013, 01:45 AM
ynots's Avatar
ynots
ynots is offline
After I completed my stage1 I was finally able to pass a prius!
Quick Reply: Stage 1 Hp & Tq
