Ever heard of "Instachop"? (plug-n-play rake extender)
Cutting and raking is the second best, this would be just above the triple trees that toss out your front end to about a 45 degree rake.
You want a raked frame, buy one and build a bike.
You start cutting and welding stuff, it gets all bad real quick and if you are talking about the skeletal structure of the machine that is hurling you down the road at break neck speeds, I'd rather be concerned about traffic and pot holes than if my rigged up half assed frame is gonna sty in one piece... ya dig?
You dont have to mess with the frame to rake a neck noob.. I'm kicking around a rake for my FXDC right now.. that dosent require a single weld to be made.. depends on the level of rake that you want.. there are NUMEROUS threads from the Dyna guys on here about this subject.. from moded trees.. to a raked cup and stem kit ... dont forget the rake and trail calculator also.. to far outside of "trim" on either end can cause major handling issues..
Here is further on what I was talking about noob:
https://www.hdforums.com/forum/dyna-...ked-trees.html
a cat who used to be on here alot named traveller also did some tree/rake work on his 05 Dyna.. you could try doing a search under his name..
