Changing top clamp
Changing top clamp
is this is a simple pull the old one off and put on new one or is there more to it? i havent done any homework on it but im assuming that pulling the top clamp loosens the forks from the neck? also with 15k on it, should i be worried about changing any bushings or anything and will it change fall away?
I might as well say it since someone will...
Get the manual
In reality, it is a lot easier than I thought it would be.
I had mine appart at 12000 miles for powder coating and the bearings looked perfect (after cleaning and repacking)
You will have have reset the fall away, but that is easy as well.
Get the manual
i actually bought a loner industries top tree thats a direct replacement for the street bob tree. i got my new top tree, forbidden risers, contour pro tapers with steel sleeves (the supplied aluminum sleeves were to much of a hassle). just waiting on my ARP bolts for the risers and winter rain so i can actually do it. i have a manual just havent had alot of time to open it.
