Risers on '14
Your risers and bars have around 12" in total height, and they are pretty wide at around 31" with a good amount of pullback. Taking that all into consideration you can probably hit a good 15-16" with no cable or line changes if the bars you switch to aren't super wide. I'm sitting at 13" total between my bars and extensions (to the top of the cross bar) and still have slack because my bars are only around 28" wide and only have around 2.5" of pullback.
Ok, that was a terrific answer but a lot more technical than I was thinking. So, basically, if I'm staying with the stock bars and I just want to raise them up,....I could change my current risers 3" to 3 1/2" risers or 2" to 2 1/2" riser extensions to my existing...and I should be ok. (?)
