bumpy roads will kill it
My son in laws 01 wide glide will die when you hit a bump , it will restart right away about 90% of the time , it used to die while just riding at a steady speed ,replaced start/stop switches which took care off that problem then this shows up 3 months later .Any help will be appreciated ,Thanks.
Last edited by jimwrench; 03-27-2014 at 11:08 AM. Reason: Sorry had wrong year model
I am no Carb guy I am a FI guy so I dont know if this is even valid but when was the last time the carb was serviced? If sounds like you are getting Spark. The 3 things you need are spark, fuel and air to get a bang. Sounds to me like when you hit a bump you are losing fuel.
yes we checked ignition switch terminal connections on first go-around while diagnosing handlebar switches .had to remove tank to get to splice connections because the concealed wiring in bars terminated in backbone ,was a bitch to get harness pushed up from swingarm area to front of backbone as I wanted to check the integrity of those terminations , voltage drop on cables proved out to be good.
Check circuit breakers next time it happens. Could be a dud breaker or could be a short somewhere when hitting bumps that trips the breaker. (Explaining why it will restart ok almost stright away, after the breaker resets itself.)
That short tripping the breaker could be anywhere on the bike. I would start looking around the rear tire / tail light wiring etc that could get hung up on a bump as the tire moves.
P Miller
12-20-2015 01:47 PM
