DK or other lowering blocks for Dyna weight limit ?.....
Guys,
Thought about dropping the back of my street bob with a lowering block kit instead of dropped shocks. My reason #1 is cost right now, #2 my wife only rides with me a handful of times a year and it would be for a long distance destination so I could easily ditch the blocks for a weekend for a little extra height for 2 up riding.
My question is I see a 200# weight limit for the lowering block kit on DYNAs on DKs website, specifically for Street Bobs. I weigh over 200# myself (not a fat *** just big) and with my wife she is another 100 or so. Does anyone ride 2up with blocks without issues? Will I have issues just riding solo because Im over 200 alone?
Thanks for any help!
JTR
JTR
The reason the weight limits are there are to prevent the bike bottoming out and the tire scraping the fender.
If you are over that weight limit, then if you hit a big bump, then your tire might scrape your fender.
If you are going to install these, I would recommend that you check and make sure there is nothing under the fender that can puncture the tire if that does happen. If you ever have questions feel free to give us a call.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
I'm guessing most should be the same. Haven't looked yet, but I believe there isn't much there usually to be a problem.
JTR
Thank you for your response. I have the wide tire kit installed on my bike with the only wires being the rear brake light (do not have rear turns or wiring) so I think these will work for now. I am going to give them a shot and see how she goes and I will report back my experience.
JTR
JTR
Also, with the wide tire and the wires, it would probably be best to route the wires to the outside of the fender, so that if it does bottom out, the scraping will not damage the wires in any way.
For most people, the best way to check and see what can or will hit, it to remove the shocks and lower the fender onto the tire. That way you can see what will hit, and exactly how much clearance you have.
