Dyna FLD Switchback question...
Hey everyone. I'm new to this site, really enjoyed reading some about ya'lls rides. I just recently bought a new FLD. I need to put some 12 inch mini-apes on it, and am wondering if anybody knows definitively if the stock cables and wires will work, or do I need to lengthen them.
I've seen conflicting posts about it (I'll admit I'm not the most savy when it comes to searching forums). Any insight would be much appreciated.
I am finding that extended ABS brake lines are hard to find, so if not necessary, that'd make life easier.
Pat
Pat
Pat
Pat
These parts (don't have numbers handy) should help you understand what is needed. Unlike the stock brake distribution block, the accessory part has upper hose permanently attached.
Just going with 12's...
Thanks for the info. I have a catalog the dealer gave me when I picked the bike up last month, so part numbers are easy...but of course, in that timeless Harley style, it says to obtain length information speak with a authorized HD service advisor. Ha.
Based on what you're saying, I should be golden. Only putting 12" mini apes on this one.
Thanks,
Pat
Thanks,
Pat
http://s7d1.scene7.com/s7/uviewer.js...sal%5FCatalog1
according to this you would need new throttle and idle cables
Found em
Was nearly ready to give up. Non-ABS will work, but ABS will not.
Pat
Harley make extended ABS lines and components, which is what I used to fit 16" apes on my ABS equipped FLD - see picture above. Only Harley only lists the parts for the Wide Glide,which has the same ABS as the FLD - both are dynas.
