Street Glide air shocks
Throw some Schrader valves on them. If you do them don't do it on a bench. Prop them up and ensure all the air is out then disconnect lines. Unscrew and install Schroeder valves. Napa part number 90-290. Pay attention to what year SG they came off and their air pressures. I think 2012 uses less max air or the other way around. Since the angle of them on our bikes have a little more leverage I've read switching the oil to 10wt is a nicer ride and less air is needed. I have the HD pump with a gauge built on it and a deflate button, and it's small. Do not use an air compressor to fill them or turn it way down. Some use a bicycle pump if they don't spend the money on the HD one.
Install is easy bolt on, but need a jack.
I re-painted my shocks and air valves with rust oleum appliance epoxy.
I'm an amsoil dealer so I use shock therapy medium. I haven't done it yet. I do it this winter maybe. I have the shock therapy in the forks and I like it. You should be able to cross reference the year with the part number. If they are the older ones search the forum and find the specs, that's what I did and keep them in my phone because I know I'll forget.
I'm running the 12" SG version on my 07. Here's something to think about ... run the air lines with one valve. That way you are insured to have equal air pressure in both shocks. I used a long spacer and longer bolt on the battery box cover and mounted the valve there. Easy to check and adjust air pressure.
I have enough fittings and stuff that I may run a single valve (running separate now) but i will have some quick compression fittings to fix a line if needed. I will also slide some rubber hose over the line to protect from rubbing.
I would suggest carrying one or two quick compression fittings in case of emergency.
Couple straight ones and a razor blade is all you'd need:
albngore
03-20-2017 01:30 PM
