Demon Cycles El Diablo 16" pic
I did quite a bit of research on these bars, but finding pics was a chore. I know Demon gets some pretty bad reviews online, but I was lucky enough to see the bars in person last week on a Wide Glide, and I thought they looked great so I bought 'em. I used the Burly 16" cable kit and the install took me about 8 hours, but I took my time, soldered wires (which were unnecessary, btw), and fought fishing electrical through bars with less than 90° bends. I've just got the one pic for now, but if you want more just let me know. If you have questions, I'm happy to answer.
And I want to thank ajpointless for his write up over here: https://www.hdforums.com/forum/frame...on-a-dyna.html
Hey bro, those bars are bad as*, I have the same ones in 14", then I ended up adding 1.5" riser extensions.
Word of advice, I dont think the chrome job is done too well on these, I am getting rust spots in the corners both on top and bottom of the bars. I thought at first it was probably due to the high humidity in FL, but I am still getting it here in SoCal. Every wash on the bike I have to use some fine steel wool to get off the surface rust, then I put a very thin layer of grease over the trouble spots, that seems to slow down the process a lot!
How was the wiring job on your bars? When I did mine I got one side through fairly easy, but the other side was a complete PITA!
My Diablos have held up great since installing them February 2013. I had mine recoated from the stock flat-black to gloss-black by Joe @ The Powder Pro before installing them. I get compliments on these bars all the time and even had someone follow me for miles and pull in behind me at a gas station just to ask me what bars I had.
