sporty shocks on dyna
alot of ebay ads list progressive shocks under sportster and then at end say (fit dyna)
granted it will probably fit will you run into any problems running shocks made for sporties on dynas?
dynas are probably 70-100 lbs heavier im thinking? and i seen some BIG PPL on sporties haha
reason i ask i have some 1200R sportster shocks i got for cheap that are 13.5 should i even bother putting them on?
Sporty rears............
13 1/2' is quite a bit longer, but you want at least 1" of rider sag to be able to utilize the extra length.
If they fit put them on and see where you are at............
Live Free = Ride Free..........
I called progressive on this issue a while back when I was looking at some sporty shocks to use on my dyna. I thought they would be too soft due to the dyna being a heavier bike, but they said even though the sporty is lighter the shocks would be way too stiff due to the different shock mounting angle (more straight up and down vs. angled back on Dyna), they are valved/sprung different. They would have mounted up but gave a bad ride.
Eric The Welder
08-06-2011 01:11 PM
