Dyno Charts This forum is for posting of your Dyno Charts. You will use a prefix to designate your Cubic Inches. When posting please include all model year, Cubic Inch and modifications in the thread title and in the body when posting your Dyno Charts.
114-120": 11 Streetglide, 120" w/ Procharger, twin intercoolers, gas ported pistons, welded crank V+H X pipe, 4" Monster Rounds
Old 12-04-2016, 11:43 AM
ramx50's Avatar
ramx50
ramx50 is offline
Default 11 Streetglide, 120" w/ Procharger, twin intercoolers, gas ported pistons, welded crank V+H X pipe, 4" Monster Rounds
11 Streetglide, 120" w/ Procharger, twin intercoolers, gas ported pistons, welded crank V+H X pipe, 4" Monster Rounds-2011-streetglide-dyno.jpg
Old 04-21-2018, 09:03 PM
dmarriner60's Avatar
dmarriner60
dmarriner60 is offline
Older post cruising, and thats incredible!
Old 04-21-2018, 09:54 PM
ramx50's Avatar
ramx50
ramx50 is offline
Thanks, here is the latest sheet after a few more tuning adjustments. DAS Performance does amazing work!
11 Streetglide, 120" w/ Procharger, twin intercoolers, gas ported pistons, welded crank V+H X pipe, 4" Monster Rounds-image.jpg
The following 2 users liked this post by ramx50:
cvaria (04-22-2018), dmarriner60 (04-21-2018)
Old 04-24-2018, 08:16 AM
13glidestreet's Avatar
13glidestreet
13glidestreet is offline
Attachment 592781
Erik just built my 110" on my bike. He was actually telling me about this bike in how its a beast! Going to need to hold on tight on this bike for sure!
ramx50 (04-28-2018)
Old 04-24-2018, 10:36 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
The best thing I see from these Procharger application is a linear streetability power delivery with no surprises as with turbo systems.
The only issues I’ve encountered tuning these beasts is the compressor drive belt coming off. Procharger may have addressed this since my last experience.
I love tuning Procharger bikes! Unlike turbo apps linear power makes for reliable and repeatable tuning without possible runaway boost causing damage.
Bob
Old 04-28-2018, 08:05 PM
ramx50's Avatar
ramx50
ramx50 is offline
Bob
Pro charger has not done anything to fix the belt issue but Eric @DAS Performance did with this set up. It is a custom 6 rib setup with custom pulleys.
DAS now sells this as an upgrade kit.
Old 05-08-2018, 08:35 AM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
You can still run it as a 4 rib system as well. The best part of the DAS pulley is the sprag clutch.
Old 08-19-2018, 07:15 AM
jdscycle's Avatar
jdscycle
jdscycle is offline
Looks awesome! Must be a blast to ride. I like the 6 rib drive belt, but have any updates been made to the belt in the primary? I have seen them break and cause quite a mess..
Old 08-20-2018, 12:41 AM
badcooky's Avatar
badcooky
badcooky is offline
Yes definitely with a Centrifugal Supercharger ,my ute (pick up) is running one of these Superchargers( http://raptorsc.com.au/ ) Tim the owner is close personal friend of mine and I'd mentioned a sprag clutch type system for the blower pulley,so yea he made one we fitted it and yep the charger free wheels during gear changes or in back it off then punch it situations it is much better , when the blow off/bypass valve shuts off you've got instant boost.
Awesome project.
GregGillette
03-23-2022 10:14 AM
Rat Trap
04-06-2017 04:15 PM
brad75raiders
Dyna Parts
15
11-10-2014 09:27 PM
FBinSoCal
10-12-2011 02:30 PM
t stone
09-17-2011 11:09 AM
Quick Reply: 114-120": 11 Streetglide, 120" w/ Procharger, twin intercoolers, gas ported pistons, welded crank V+H X pipe, 4" Monster Rounds
