Decorative Led's killing battery
24mV? Do you mean 24mA? Volts is force potential, amps is current flow. Volts present will not drain your battery, current flow will. 24mA will drain your battery if it is connected long enough and how long it takes to drain the battery will depend on the health of the battery.
Readings for parasitic amp draw are best taken at the battery. Disconnect the battery negative cable, put the amp meter positive lead on the cable and the negative lead on the battery post. Set at the max amp setting and read.
DO NOT CRANK...that will blow the fuse in the meter.
Good luck!
Good luck!
The following 2 users liked this post by skinman13:
benscratchin (12-12-2016),
larsfum (12-07-2016)
Good luck!
Good luck!
