Cigarette lighter plug-in not working any more
Old 08-19-2014, 03:51 PM
silvertex1's Avatar
silvertex1
silvertex1 is offline
Stage IV
Default Cigarette lighter plug-in not working any more
I plugged in a Satellite Radio into the cigarette lighter for a couple of years on my 2008 Ultra Classic . All of a sudden the plug in doesn't work any more. Have checked the fuse and it is fine. Any suggestions or help would be appreciated.
Old 08-19-2014, 11:33 PM
cficole's Avatar
cficole
cficole is offline
Which fuse did you check? On the bike? There might be one in the radio plug, too.
Have you tried anything else in the lighter jack to see if it still gets power?
Old 08-20-2014, 02:52 PM
silvertex1's Avatar
silvertex1
Stage IV
Yes I have, nothing else works in the plug-in either.
Old 08-20-2014, 05:40 PM
cficole's Avatar
cficole
cficole is offline
I'm not familiar with the way the wiring is done on the bike, but some general principles apply.
If you've got power at the fuse, and no power at the jack, then the problem is in the wiring between the fuse and the jack. Check the ground at the jack, and work your way through the wiring from the fuse to the jack with a meter. I'd expect you to find an open wire or a bad connection somewhere.
Old 08-20-2014, 06:03 PM
ACE 1968's Avatar
ACE 1968
ACE 1968 is offline
My port is not working either but I think mine is in the switch and I am not sure how to get to this I can take ignition key out but cannot remove plate that switches are on off I took out screws on side but no luck getting plate off 08 Electra glide
LarryLives
05-24-2016 03:45 AM
brad75raiders
Audio Systems
05-12-2016 01:41 PM
lowrider198
09-07-2010 04:16 PM
alandchris
01-28-2009 05:09 AM
pointswhat
08-27-2005 04:15 AM
Quick Reply: Cigarette lighter plug-in not working any more
