Crankpin Nut Loctite?
Old 09-23-2014, 02:24 PM
97EvoBasket's Avatar
97EvoBasket
97EvoBasket is offline
6th Gear
Default Crankpin Nut Loctite?
Crank / Flywheels in question are out of a 97 Evo.
It came out of a bike with roughly .0035" runout (just outside the inner tapered bearing on the output shaft side - so probably slightly more closer to flywheel where the bearing rides).
Long story short I took it to a local shop and got it back with .006"+ runout on the pinion shaft after they "trued it" and reassembled the lower end with new bearings.
I am going to do this myself, because apparently you cannot trust some people and I am low on funds as a result of it. I have the equipment required to measure it. But only a lead hammer, clamp and wedge to adjust it. I know the general procedure, with a lead hammer and a wedge and clamp.
What formula and how are people applying loctite to the Crankpin nuts?
I don't think I can true it in under 20 minutes before the red loctite sets up.
Would the nuts need to come off to true it and would you trust it as assembled, just moving it to true?
Seems like since I will have it out again, that it might be worth seperating and checking the pin and rod bearings even though they feel good.
Let me know what you think.
I am almost beginning to think this bike is cursed......
Old 09-23-2014, 03:10 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We use the what Loctite used to refer to as RC-680, on the nuts, light film on the tapers, and lock screws if so equipped.
You are going to need a torque multiplier(and torque wrench) to draw those nuts down, and a way to hold the wheels once doing so.
Our Proto mulitipler was about $500.00 or so, back when we bought it.
FWIW, we have about $7500.00-$8000.00 tied up in equipment to balance, assemble, re-build, and true flywheels here, not even counting the several custom arbors, and bob-weight adapters for odd-ball stuff.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 09-23-2014, 04:06 PM
97EvoBasket
6th Gear
Scott,
I can appreciate your equipment costs, as I am in the manufacturing field.
My understanding has always been that tapers should be white room clean and dry.
Do you use the large angle plate as a clamp and bar setup for adjusting any scissor?
Also, what is the benefit of the torque multiplier if your torque wrench is suitable for 200-220 ft-lbs usage?
You clearly have more experience than I, so I am all ears.
drfalken
05-30-2021 07:53 AM
Brawny MMC
06-20-2011 11:17 AM
sniper77
08-14-2010 02:52 PM
98fxd
General Topics/Tech Tips
04-21-2005 12:15 PM
Quick Reply: Crankpin Nut Loctite?
