100" twin cam
Not a common configuration; better cost/benefit ratio, i.e., more for the money by going with a larger bore. Same cost to case bore for larger cylinder spigots, same cost for bigger bore cylinders and pistons so for the same money might as well go to 107" (4.125" bore x 4" stroke). That configuration is referred to as an "all bore" 107" motor and being "over square", is a real work horse. Spending the same $$ to end up with nearly 10% less displacement and performance doesn't make sense.
113" = 4.060" bore x 4.375" stroke but if you have to case bore and replace the 4" crank with a 4.375" crank, might as well increase bore to 4.125" and go to 117"; same scenario, same cost but more displacement which means more TQ/HP. Believe me, if you stop at 113", you will be kicking yourself in the butt bigtime.
They actually gave us a set to use on a clients engine to R&D, and in turn we gave them to the client.
Bike is still in service over in Syracuse, NY, with 116/116, carbed, Wood cams, staggered dual Supertrapps.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
A "square" engine that really produces very well is an 88" XL.
3 13/16" X 3 13/16".
We've built many of these here, with one of the top-producers coming in at/near 120 hp.
Bear in mind that this is a result of the cylinder heads ability to allow power to continue out past 6500 rpms, with the dedicated engine combo.
Scott
Scott
scott @hillside
Scott
Scott
Axtell no longer manufactures those 4" holes.
98" is the way these days and we bore your OE cylinder here, using our proprietary Wiseco piston/Cometic gasket kits.
In order to ramp the torque in asap, a Wood TW-6H would be a great cam.
At .590" lift, it would also require a set of valve springs.
A DTT ignition would bring it all togather.
Scott
Scott
venturaoutfit
Softail Parts
10-25-2012 12:44 PM
