Twinkie rebuild : lets fix it once and for all. ideals ?
I have a 2000 ultra classic.
She's a scorching hot sun of a gun.
Bone stock.
I want to leave it basically stock. But lets get rid of the extreme heat.
And fix the motor shake at idle.
And fix the buzzy floorboards.
I do have vance and hines 2-1 exhaust on it. Only reason we did that was to move the pipe away from the passengers floorboard, it fried my wifes right foot.
I don't care what i have to do. Plz give me your ideals on what to do.
Thanks.
Bone stock.
Thanks.
Engine cooling fans such as the Jims Forceflow or the Wards fans will lower head and cylinder temps substantially. A good oil cooler will lower oil temps, but not head/cylinder temps (much). Getting a good tune could also make a difference if your current tune is lean.
First place to start on the vibration issue is the motor mounts.
Bone stock.
Thanks.
Bone stock.
Thanks.
Wards fan setup will cool things down a bit and an oil cooler as has been suggested.
A good fuel management system and proper dyno tune should help as well.
I've owned the GL1800 . Great bike. Loved it.
Too tall. Too heavy.
The ultra fits me perfect.
I don't mind a little shake. But not paint shaker style. Mine shakes so hard at a stop light my vision is blurred. That's not normal.
Ok... called a shop.. he say ?
Motor mounts. Yes.
Oil cooler .yes.
Tear down weld and true crank.
Replace cam chains with gears.
SERT ???? Computer chip ? Re tune , slow down idle.
He thinks she's running way to lean.
And of course dyno.
We shall see.
Sounds like the front motor mount has failed or is worn out. 15 years old if it is the original one. How may miles?
The front motor mount also gets drenched in oil a lot of the time from changing the filter.
Also check the stabilizer rod ends. Probably some wear there with the engine shaking that hard.
Received 70,440 Likes
Motor mounts. Yes.
Oil cooler .yes.
And of course dyno.
We shall see.
Motor mounts. Yes.
Oil cooler .yes.
And of course dyno.
We shall see.
Gear driven cams will not affect heat or vibration, only improve valve timing. Not needed for a stock motor.
Oil cooler will cool oil a good bit (good for motor), but will not substantially affect the major source of engine heat - heads and cylinders. I have both a Jagg 10-row oil cooler and a Jims Forceflow fan. The latter does MUCH more to lower engine temps.
I would focus first on the motor mounts and getting a good tune...
May need nothing more than a skilled tuner to attend to the needs on the MM system, to tame the shaking, and heat as well.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
