question about 95" and 96" engine
Old 04-08-2016, 09:07 PM
hoozdis's Avatar
hoozdis
hoozdis is offline
Default question about 95" and 96" engine
how did Harley end up with 2 engines only being 1 cubic inch different?
95 & 96 cu in
Old 04-08-2016, 09:27 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,030 Likes on 651 Posts
95 was by bore. 96 was by stroke
88 with the big bore kit was a 95
88 with the longer stroke was the 96
That's why the big bore cylinders would make a 88 a 95 or a 96 a 103. The Pistons have different areas that the pins go through for the different strokes though. I hope I explained that well enough or accurately
Old 04-08-2016, 09:32 PM
hoozdis's Avatar
hoozdis
hoozdis is offline
so a big bore kit would make my 96 into a 103? would the lower end have to be opened up?
Old 04-08-2016, 11:02 PM
fidel's Avatar
fidel
fidel is offline
no just bore ur cylinder and new piston u get a 103
Old 04-09-2016, 01:37 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Just find a take-off set of cylinders and pistons on E-bay or in the Classified section here, have them cleaned up and swap them out on your motor.
Old 04-09-2016, 09:04 AM
hoozdis's Avatar
hoozdis
hoozdis is offline
I will keep that in mind, this Harley stuff is addictive and expensive. I have an rbracing 2 in 1 coming in today
Old 04-09-2016, 03:54 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
You can even bore your stock cylinders to take your bike from 96" to 107"...
Old 04-10-2016, 08:18 PM
azlou66's Avatar
azlou66
azlou66 is offline
You sure can see my sig.
CaptainHook
02-26-2016 06:59 PM
pipercolt
06-08-2014 05:14 PM
aggiejason
05-19-2013 07:50 AM
steveh326
10-22-2010 10:53 AM
swomack
04-24-2007 02:38 PM
Quick Reply: question about 95" and 96" engine
