Help: twin cam 88- cam journal marred up
Old 04-14-2016, 07:43 PM
Mr_mayhem77's Avatar
Mr_mayhem77
Mr_mayhem77 is offline
Default Help: twin cam 88- cam journal marred up
Help, tore apart my twin cam 88 bottom end after my oil pump broke and cam bearing came apart. Marred up one cam journal pretty bad picture attached .
I'm a machinist so all I can think is fresh bore and larger bearing OR bore and custom bushing . What do people do in this situation!?
Attached Thumbnails Help: twin cam 88- cam journal marred up-image.jpeg
Old 04-14-2016, 10:38 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
Press a new bearing in and see if it is tight? Is there a adhesive to use ??
Old 04-14-2016, 10:44 PM
Mr_mayhem77
Thanks for the reply . Yes , this could work. Maybe jb weld for good measure . It's still measures a proper interference fit.. I will attemp to clean any burs and get Torrington bearings . Fingers crossed .
Further advice welcomed
Old 04-15-2016, 04:24 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
If the bore was damaged to the point that I had to do something about it I'd send the cases to Vee Twin and have them bored to accept the B168 inner bearings.
Then I'd ebay an 07 and up hydraulic plate and cams. You'll wind up with a good fix and have a wider selection of cams if you ever decide to go that direction.
Old 04-15-2016, 08:28 PM
06 Ultra Classic's Avatar
06 Ultra Classic
06 Ultra Classic is offline
From the dink mark on the edge of the bore , I wonder if there was a tiny fragment riding in there for a while? Was it still the original cams in there?
Scott
Old 04-15-2016, 09:46 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
I would not trust any loctite or adhesive as suggested. Send the case to John Dahmer at Hoban brothers and have them install the steel inserts.
Old 04-16-2016, 09:41 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
If in need, we've repaired cam bearing bores for yeeeeeears here.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 04-17-2016, 05:44 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
We repair all too many here.bore the hole & sleeve it back to size.use your cam plate to indicate hops
Mike Cruzr Scherban
10-04-2017 07:59 PM
oakspeed
2014-2023 Touring Models
25
11-14-2016 02:30 PM
Biker Boy 53
08-27-2015 08:48 PM
Thumped
10-14-2013 07:01 AM
djack
10-15-2011 12:40 PM
Quick Reply: Help: twin cam 88- cam journal marred up
