Breather Bolts holding air breather bracket
Does somebody know what is behind the breather bolt that holds the bracket that keeps my Carb in place. I have a 2002 Harley Fatboy with partially stripped threads. Located just below the chrome block covers. It is on one of the two bolts only. I already have the Heli Coil Kit to repair it, but have been reluctant to do this job because after you screw in the Heli Coil there is a very small little clip that's part of the Coil that must be broken off. This little clip as I'm calling it, is there to allow the bolt to screw down the coil, but must be broken off to allow the new bolt that will now hold bracket to be tightened. The problem is that I don't know where the breather hole leads to, which concerns me in case the little clip that is usually broken off with a screw driver, and the light tap with a hammer. In this case because I don't know what it goes, had thought of using some very small needle nose pliers, and am thinking ahead in case it slips off the pliers and falls in. BOTTOM LINE: WHERE DO THE BREATHER HOLES LEAD TO. SEE PHOTO
It's basically a hole in the cylinder head that allows the motor to push air (and some oil at times) out of the motor - hence the "breather" bolt, which is hollow inside and allows the air to pass through. As for what's behind it, it's just a hollow port that goes up into the head/rockerbox area. Don't have a schematic that I can attach at the moment...
I just need to be sure that if a little piece of the coil which amounts to about the diameter of a paper clip but less than a 1/4" long falls in there it can't cause any damage. If it can I may have to take it to a professional that has the tools to break it off without it falling into the hole. Thank you for your help
You could always take off the top cover on the rocker if you really wanted to..
Griz
ScreamingSkulls
2014-2023 Touring Models
02-04-2017 11:31 AM
BIGDADI
04-25-2009 09:12 PM
