Now what? Advice and help needed
#221
re-using gaskets like that is a fools game IMO... better use RTV.
#222
Received 4,317 Likes
I don't reuse metal gaskets but all the others are reusable.
I have done it with no leaks several times.
The only thing that matters is if the gasket comes off in one piece.
#223
You'll need to pull the lower rocker when you put it all back together. All in the FSM man... read it carefully. Go with James gaskets for everything but the rocker box base gaskets... use the HD ones I sent you for that; they're the rubber coated steel ones. The james rocker box gaskets are great except for the base gaskets.
The James ones are steel and silicone too, its all I ever use. You can do the job without removing the lower rocker base if you pull the rocker shafts.
But knowing the Op's luck it might be time to change them while winter is upon him.
#226
#227
I'm trying to figure out what to order and what not to. I'll post a pic of the paper James its part of the kit JGI-17042-92. There's many variations it seems. As of right now I removed the rocker shaft exactly as shown in the sticky spanners did. Haven't touched the lower box yet otherwise.
I am debating on just ordering one upper lower middle and one umbrella vs ordering a whole kit. If I need anything else the prices get close and I think I might need a few random pieces.
T, you send me a bunch of o rings in various sizes not sure about those yet either. Did you send two pushrods worth?
#228
Like I said... either piece that stuff together, or buy new kits and keep the extras because you never know... those extras have come in handy for me.
I'm not worried about it because my motor is getting torn down for a 2nd time in 2015 for a complete and final build, so I don't need the extras right now... if she dies again she can just sit again. lol
#229
