Rookie move now what?
Old 12-09-2015, 02:48 PM
byronk's Avatar
byronk
byronk is offline
Default Rookie move now what?
Well I got the top end back together and with the top end gasket kit (cometic) there was two gaskets for the cam cover. I have an S&S bottom end btw and my bike is a bottom breather but I installed new rocker boxes and im gonna set it up for top and bottom breather. Anyways I had already bought a gasket and put the cam cover back on not aware there are two different gaskets, one that just goes around the outside of the cover and one that has a "window" in the bottom left corner. Well of course I put the wrong one on and need to pull the nose cone to replace it. Can I do this with the top end assembled? Or do I need to cut the pushrods out to get it off?
Old 12-09-2015, 03:08 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,707 Likes on 1,343 Posts
I have never tried it, but there is said to be a magic position where there's no load on any of the valves and you can pull the cone. It's come up here recently. One of the big wrenches mentioned it, SORRY, I FORGOT WHO, John or Spanners, I think.
Old 12-09-2015, 03:16 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
You can do it with the top end on, you need to set the notch for the ignition cup in the end of the cam to the 5 o'clock position and make sure you push on the cam as you pull the cover off.
Old 12-09-2015, 03:17 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Never mind Spanners got in before I finished typing!!
Old 12-09-2015, 04:30 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
who told you you can convert a bottom breather to a top breather by just changing the gaskets -- or did i miss something
Old 12-09-2015, 05:34 PM
byronk's Avatar
byronk
byronk is offline
Boy am I glad to hear that, thanks Spanner!
Old 12-09-2015, 05:38 PM
byronk's Avatar
byronk
byronk is offline
Not converting it John just going to use both. I changed the rocker boxes to ones with umbrella valves and removed inserts from the heads. Now just need to figure out what backing plate I need for my S&S carb or maybe switch to a different A/C setup.
Old 12-09-2015, 06:13 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
question Y -- the bottom breather was on every motorcycle made in the USA from the 1900s to emissions was mandatory
plus think about it this way - the pistons are like 2 upside down water glasses moving downward at a hi rate of speed into a small pocket so the oil and air is blended together - then when the rotating breather valves opening come into the engine blocks window - a rush of air and oil < what does it do ??? lubes all in the cam chest and neturals the air in the oil tank so as not to loose the oil feeds prime ( oil tank to oil pump intake )
the remaining air that is trapped in the lower unit is again sent back in to the heads and it also aids in lubing the top end of the motor / then the cycle starts all over again
if i am incorrect about this i am sure someone will have a better description of how this all works
when you open a second air escape that did not come on a bottom breather or on a top breather, you create a void ( dead spot ) in the vacuum as i see it that is needed to help purg the lower units exit into the cam cover - to me this will cause the lower breather hose to spit out oil while your driving
someone else have a say in this i would like to hear it /
Old 12-09-2015, 07:22 PM
texashillcountry
Dirt don't hurt
FWIW a friend of mine has both on his but either I came that way or PO modded it.
Its a thunder mountain with a 113 S&S motor.
Old 12-09-2015, 07:28 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
being an S&S motor it might have a reed breather - that changes things
Quick Reply: Rookie move now what?
