Opinions/Advice 1993 90th Anniv Electra Glide
Hi all,
I've just joined the forum and would appreciate any advice or feedback.
I have the opportunity to purchase a 1993 90th Anniversary Electra Glide Classic. It's available through a friend (not on open market). The bike hasn't been ridden for a couple of years due to owners health. He got the bike running for the owner, needed a battery and carb kit.
The bike has under 30k miles and is original owner. Cosmetically I'd say it's a 9/10, completely original even has stock pipes and cassette deck. At this stage the bike needs a new belt, current one has rock imbeded in it and about to go. The rear base gasket is leaking, and tires are dated 2000 so I imagine hard as a rock. As its sat so long I imagine all fluids would need changing.
My questions are;
1) Any guesstimate hat the bike is worth as is.
2) Anything else to look out for?
3) Any comments, upgrade suggestions.
Thanks all, I really appreciate your time.
My questions are;
I wouldn;t care about an 'anniversary".
changing the belt in labour intensive- the complete primary drive needs to come off ( clutch everything) the swingarm has to come off.
this is the times to replace the bushings on the swingarm
tires, fluids, brake lines, fluid rebuild the master cylinders and calipers.
all can be done at home if you are savvy.
Mike
Mike
ozbatts (04-19-2016)
I bought a '90 last year.
If put the value around $5k to $6k, more or less, assuming it presents well. Super clean, near perfect units might get more. Not a lot of us goofballs looking for these older baggers.
Things to look for? Pretty much everything. Tires, brakes, fluids are a given. From there, it's just a matter of troubleshooting stuff as it happens and/or upgrading stuff as you see fit.
I first "went Evo" a couple of years ago. My overall impression is that these things need a bit more care and feeding than the newer stuff, but the ownership experience is far more satisfying if you're the type that wants that sort of relationship with a bike.
A 30k EVO in original condition. I'd take it in a second.
Are you mechanically inclined? You can get a manual for instructions on all the work but the tools and knowledge of how to tackle everything will be a factor.
Nadaguide has a good guide for values. Considering the lack of use and the significant maintenance, I'd be looking for a significant deal. Those things can be done in a weekend by someone experienced but would take considerably more time if first time. If you need a pro to get the bike road-worthy you'll likely spend more than a bike which is already maintained and safe to ride as is.
2) 93 was transition year (I own an 93 FLHS-ElectraGlide Sport) for the touring models. Factory cam sucks, carb is EPA choked, cam bearing is cheap junk. Wheel bearings are the old school pack your own type (a good think, IMHO). If the tires are old, the bearings need to be cleaned/packed when you buy new rubber. The base gasket leak is common. Mine leaked for 12 years before I got it fixed. Bad design on how the oil returns from the heads to the case. It's a good 4+ hour job to do them. I think the Stealerships got 6 hours labor to do them. The belt may or may not be in need of replacement, more on this below.
3) If you want a bagger and can get it really, really cheap (under $4k), then it's a good deal.
Immediate needs: Tires, wheel bearing re-pack, spark plugs, fluids (oil, transmission, primary) change. Brake system flush and fresh fluid. Fork oil probably needs to be changed too. Hit all the Zerk fitting with some grease. Lubricate the throttle cables and speedometer cable too.
Upgrades: Cam, exhaust, air cleaner. EVO's were strangled by the EPA (noise and emissions) and barely put out 50-60 hp. They need to breathe: Air In, Air Out. I remember my new 93 was a DOG in stock configuration.
Most Harley Stealerships won't even work on an EVO. I've had at least two dealerships tell me: 'We don't work on bikes more than 12 years old'. Don't know why 12 is the magic number.... Soooooo.... If you need repairs/maintenance, you'll need to find a GOOD bike shop to do the work for you. There are a lot of places that say they can work on Harleys, but a lot of them haven't a clue.
Good Luck.
If you can't do the work yourself, you would be better off to leave it alone... unless you can get it really cheap.
Hi from the UK and welcome to HDF. I've owned my 1990 Glide from new. Adding to the comments above, we each of us establish a 'line' up to which we feel able to tackle jobs on a bike. Changing belts is beyond my own threshold, so I entrust my local friendly indy for such work and other jobs that require skills beyond my own.
However it is right to say that owning an older bike like that 90th would be most wisely done with some mechanical knowledge, so that you can do the routine stuff, at the very least. Now some of the chaps in here would give their right arm for a chance at that bike.....
Received 4,317 Likes
