Evo hvhp pump help
Evo hvhp pump help
Just got my s&s hvhp pump and need some confirmation on the oil line routing. I have cover 31-6079 and from what I figure hole 5 should be the the oil tank to pump feed, hole 4 should be pump the filter.
See pg2 for the cover hole numbers.
https://www.sscycle.com/docs/default-source/instruction-sheets/51-1126_hvhpoilpumpkits_20130618.pdf?sfvrsn=2
