need help asap routing oil lines
hoping to get this done today so here it goes... Think I have my oil lines routed wrong (single cam evo with stock oil pump and remote filter in a custom bike). Right now I have my lines run as follows... #1 as the return, #2 as the feed. and blue as the breather to my tank (which im pretty sure this one is right) but I turn it over to prime the pump and oil pukes out the fitting on the bottom of the pump (see pics). Is the fitting on the bottom of the pump actually the return? if this is the case, what do I have my return hose plugged into? just need to figure out what is what so I can get to riding!!
Here is the fittings on the pump, I have #2 as feed and #1 as return.
Here are 2 pics of the fitting on the bottom of the pump which faces tword the front of the bike, not sure what this fitting is. any help would be awesome.
I just looked at my Evo. The blue is the vent. The port you have numbered as 1 is plugged. The port you have listed as 2 is the inlet (from the tank). The port that is flowing to the floor is the outlet (to the filter which is why it faces forward).
