Oil drain plug for s&s evo crankcase
Old 04-03-2014, 05:47 PM
cyclepath37's Avatar
cyclepath37
cyclepath37 is offline
4th Gear
Default Oil drain plug for s&s evo crankcase
I have an s&s 84-91 style crankcase for an evo that i had to easy-out the drain plug. The plug that was in it was a flangeless style that uses an allen key drive. I'd like to get a magnetic one that has a hex drive head. Anyone have a recommendation or what is even the correct plug I need?
Old 04-03-2014, 06:06 PM
im's Avatar
im
im is offline
If you have the removed plug in your hands, consider taking it to NAPA.
The folks at NAPA auto parts will measure thread/pitch and length and then they will show you catalog page so you can choose.
Are you sure that was an oil or transmission drain plug?
Welcome to the forum.
Old 04-03-2014, 06:11 PM
cyclepath37
4th Gear
Yes that would be a good idea. Yes it is the crankcase drain plug. Thanks
Old 04-03-2014, 10:36 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
That's not a drain plug. I believe it's a casting plug of some sort. It's not meant to be removed. You drain the oil from the tank.
Old 04-04-2014, 05:22 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
You don't need a magnetic plug there, as it will do little if any good. They are suitable for sumps like the trans and primary, but all your engine oil gets circulated around the engine via the oil filter. Just clean it up and refit! It only serves to drain surplus oil, such as after sumping.
Old 04-04-2014, 08:33 AM
Tailbreaker's Avatar
Tailbreaker
Tailbreaker is offline
My thoughts exactly.
jengster
03-09-2021 04:55 PM
darylnj
EVO
01-04-2013 07:07 PM
mikes4692003
08-11-2009 05:50 PM
west texas
01-12-2009 09:08 AM
roadhawg
EVO
07-21-2007 07:34 PM
Quick Reply: Oil drain plug for s&s evo crankcase
