question on swapping a 4 speed kicker on a 5 speed evo...
Old 06-30-2014, 09:48 AM
jeffkimkp's Avatar
jeffkimkp
jeffkimkp is offline
Default question on swapping a 4 speed kicker on a 5 speed evo...
I found a great deal on a 88 heritage that has 5 speed. I wanted to buy a hardtail frame and use the motor. but was wondering if a 4 speed from a shovelhead or any 4 speed be compatable?
thank you again.
Old 06-30-2014, 10:46 AM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
I believe that will depend on the frame you buy. I have not seen anybody mpunt the tranny plate to an evo frame from a 4 speed. This sounds like more work than I would wanna get involved in. I do see that most aftermarket frames are made for softail style drivetrains and even the ones that are hardtails and or swingarm models. I just can't be 100% certain however. The 1984 softail came with a kicker but I am sure that is a rare and expensive item. If you already have shovel tranny then see if Johnjz can answer your questions. He seems to know a lot off the top of his head. Maybe pm him??
Good luck and report back regardless of the outcome as this question has been asked and will be asked but is rarely ever answered.
Tom
Old 06-30-2014, 11:01 AM
Beemervet's Avatar
Beemervet
Beemervet is offline
If the objective is to have a kicker, get a kit to add one to your 5 speed, or just buy a 5 speed trans with kicker. Trying to use a 4 speed is a step backwards.
Old 06-30-2014, 01:36 PM
Blue SOG's Avatar
Blue SOG
Blue SOG is offline
If you're buying a rigid frame, buy one set up for the tranny you want. Pan, Shovel, evo motor mounts are the same. The frame is built for the tranny. You'll also have to determine if you want drum brake or disc and chain or belt.
Old 06-30-2014, 04:27 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,234 Likes on 5,406 Posts
You can buy a 4 speed hardtail frame and it will bolt right up...but then you have to buy a 4 speed, clutch, and complete 4 speed primary with starter, or beltdrive...and after spending all this money...you will have to register it as a "special construction"...it will no longer be a harley on the title...which will make it worth less money, and can cause insurance headaches...sure you want to do this?...5 speed kickstarts are pretty cheap.
Old 06-30-2014, 05:52 PM
jeffkimkp's Avatar
jeffkimkp
thank you everyone for your help. and yea i will keep it a 5 speed.
nellis003
EVO
02-11-2016 03:54 PM
AlCherry
08-15-2015 09:40 AM
4stroke
Shovelhead
04-07-2013 01:42 AM
ChiliPepperGarage
Custom Models
04-22-2010 01:30 PM
hawgdawg
12-26-2005 11:12 PM
Quick Reply: question on swapping a 4 speed kicker on a 5 speed evo...
