engine swap
Old 02-28-2017, 03:33 PM
tomkennedy51's Avatar
tomkennedy51
tomkennedy51 is offline
Stage IV
Default engine swap
can an engine from a 2008 flhtcui be installed in a 1995 flhtcu
Old 02-28-2017, 03:35 PM
Scudda's Avatar
Scudda
Scudda is offline
Received 3,232 Likes on 945 Posts
You just joined the forum..you should go introduce yourself first before you post an open ended question like this and my guess would be no
Old 02-28-2017, 03:47 PM
tomkennedy51
Stage IV
Just to clarify things. I have a 1995 Ultra Classic with S&S carb. It has over 125,000 miles on it and i figure I should change or rebuild before I make any long trips. I've seen an engine from a 2008 fuel injected Ultra Classic used with low mileage. Can I use it for a swap and go back to carb.
Old 02-28-2017, 04:02 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,107 Likes on 17,549 Posts
Simple version no, somewhere in the forums this has been explained in detail a couple times. Too much different.
Old 02-28-2017, 04:59 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,940 Likes on 3,375 Posts
Hey, welcome to the forum. No you can't, unless you want to do a lot of cutting, welding and then properly aligning it all... Cheaper to buy a new Bike.
I don't live far from you and can aide you in rebuilding if you like. I'm In Selden...
Old 02-28-2017, 05:20 PM
tomkennedy51
Stage IV
Default Thanks
Thank you everyone. I appreciate the responses and offers to help.
Old 02-28-2017, 06:28 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,338 Likes on 1,948 Posts
Why on Gods green earth would you want to put a twinkie in an EVO frame!!!!!
Old 03-01-2017, 10:53 PM
jammerx's Avatar
jammerx
jammerx is offline
You can put a twin cam in an EVO...
84 FLHTC with a 96" twin cam, I took the picture.
A 2008 would probably be challenging, but doable.
Old 03-02-2017, 06:53 PM
TwiZted Biker
Anythings doable , question is will it be worth what it takes in the long run and how much extra has to changed along with the engine.
Not a drop in project for average garage guy.
Old 03-03-2017, 07:29 PM
jammerx's Avatar
jammerx
jammerx is offline
True, but most motorcycle projects are not worth in dollar value, but to the owner its a labor of love. To shoe horn a 2008 twin cam into a EVO frame would be a cool project to someone with the time.
cycocycle
EVO
20
06-10-2019 08:19 AM
first95ultra
04-23-2018 06:16 PM
PappyUSMC
11-23-2011 11:19 PM
hdfyrfighter
08-07-2011 03:51 PM
Quick Reply: engine swap
