Just changed my stock air cleaner to a screaming eagle high flow cone. What's better buy? Vance Hines fuel pak or power pro auto tuner? Have vance hines side shots. Thanks for the info!
Power Commander V, TTS Mastertune, Screamin' Eagle Pro Super Tuner(SEPST), or the T-Max Auto Tuner.
The TTS Mastertune seems to be the favorite amongst tuners, and by favorite I mean doing what it claims to do. http://www.mastertune.net/
You need to decide if you want to tune your bike yourself, or have someone else tune it for you. There is no point buying something, then finding your local tuning shop won't touch it!
I would use a tts master tune or a screaming eagel pro tuner. For the best results i would have someone do the tuning for you. their is no tuner out there that can be tuned at home with out a dyno. I wouldnt try to do the tuning yourself.
I have the Power Vision which I guess is an extension of the pc-v. But like it was mentioned above you have to have a product that your tuner can and will work with or it's nothing more than a paper weight.
