flathead serial number
Old 03-08-2010, 08:19 PM
dingwad's Avatar
dingwad
dingwad is offline
Stage III
Default flathead serial number
my serial number is 49S****.
It appears to be a wr motor.
does that seem right ?
Old 03-10-2010, 09:31 PM
Speeding Big Twin's Avatar
Speeding Big Twin
Speeding Big Twin is offline
If it's a 1949 WR motor I would expect the serial number to be stamped in a similar fashion to the example below:
In my serial number collection I have one example which is 49S++++ but that is a Big Twin Flathead and obvious reasons suggest it wasn't stamped at the H-D factory.
Could you post a partial photo of your serial number. Also have a look at the bottom of each crankcase half near the forward outer edges and let us know if you find anything stamped there.
And you could try contacting the people at beautyofspeed.com:
http://beautyofspeed.com/welcome/ema...O.S%20Homepage
There's some racing bike info on their site. Eric
Old 03-11-2010, 06:52 AM
dingwad's Avatar
dingwad
dingwad is offline
Stage III
My title says 49S****.
The cases are unstamped.
The numbers by the seam are ?48 7998.
The cases have ball bearings.
Old 03-11-2010, 10:54 PM
Speeding Big Twin
Quote: ‘The cases are unstamped.‘
But does it look like the serial number boss was stamped at some point? Please post a clear photo of the serial number boss.
You mentioned the numbers by the seam are ?48 7998. They are called crankcase numbers or belly numbers and I'd like to know what that first character is. I suspect it’s going to be either 3 or 4 but I’d like to see a clear photo.
Are there any casting numbers or casting date codes visible and if so can you post photos of them.
And there’s something else to consider. Harley-Davidson built a 1949 Model S but it was a 125cc single cylinder bike. So if your title says 49S++++ then it's possible that title was originally for one of those single cylinder models and has nothing to do with the engine you have.
I’m going offline for a day or two but I'll check in when I get back online. In the meantime please post those photos. Eric
Old 03-16-2010, 01:24 AM
paolo4930's Avatar
paolo4930
paolo4930 is offline
5th Gear
Hello my flathead serial number is 495.
____________________
Office Furniture
Old 03-17-2010, 11:55 AM
Speeding Big Twin
Quote: 'Hello my flathead serial number is 495.'
Hi paolo, are you looking for info regarding your serial number? If so, can you please elaborate on that and also post a photo. Eric
Old 04-01-2012, 01:20 PM
Classic Motorcycle Consignments's Avatar
Classic Motorcycle Consignments is offline
Stage II
Default WR motor numbers
I have a new WR motor that does not have a motor number stamped but matching belly numbers.Bought straight from the factory back when...
How do I translate the belly numbers?
Thanks for the help.
Old 04-03-2012, 12:48 AM
Stage II
Old 04-04-2012, 03:15 AM
Speeding Big Twin
CMC, what makes you think it's a WR motor as opposed to a WL or some other type of similar V-twin?
What are the belly numbers? Can you post photos of them please. And can you post photos of both sides of the engine.
Eric
Krita1
General Topics/Tech Tips
03-07-2019 06:16 PM
blakely509
Flathead
12-14-2017 08:42 PM
bikelove44
Flathead
07-29-2014 05:50 AM
Puppy
Flathead
01-11-2014 08:54 PM
JWRider
09-28-2012 05:34 PM
Quick Reply: flathead serial number
