Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Brake Bleeding Made Simple
Old 03-19-2006, 09:39 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Brake Bleeding Made Simple
If you have one of those problem brake systems that you just can't get bled properly, try this......
After you have bled the calipers good, turn the bars all the way left, then tie your brake lever in the "squeezed" position with a bungee or the like, fill the master cylinder and go to bed. In the morning before you release the lever, tap around the outside of the cylinder and line with a hammer handle and watch inside the cylinder at the bubbles that come up in the fluid , test your brakes and make sure all is OK then go ride!
And also Here's some info on bleeding the brakes and hydrallics on most vehicles... HERE
**Here's an excellent link for bleeding those brakes... HERE
jwnusbaum
07-05-2020 03:32 PM
clackavosticus
09-07-2018 05:10 AM
Nick Sorgio
Shovelhead
05-15-2017 08:37 PM
frogg
05-31-2009 01:30 AM
Trail Rider 7
01-09-2006 04:37 AM
Quick Reply: Brake Bleeding Made Simple
